TwinTurbo.NET: Nissan 300ZX forum - You've verified the coolant sensor is operating in spec?
Subject You've verified the coolant sensor is operating in spec?
Posted by jzack on September 05, 2013 at 7:12 PM
  This message has been viewed 176 times.
In Reply To Idle Issue While at Operating Temp posted by 1990Z32Guy on September 05, 2013 at 07:02 PM
Message Not that expensive or hard to replace either. Might also want to check the coolant connector - fairly common for the wire to frey near the base of the connector plug. Replaced mine years ago for that issue but it wasn't causing this issue.
Further - my bad coolant sensor (done years after fixing the plug) did cause the climate control system to work very weirdly once it went bad...
